| I've used Agxplore's Gropak for probably 6-7 years now. Tested it a few years and saw pretty consistent response in both beans and corn, and it's been standard practice for me since. It's quite a bit cheaper than some of the other's out there. I put on probably half the label rate because at labelled rate the seed doesn't hold it and it builds up in the tanks etc. I think I end up with $1.5-2/ac in it. I've tested a few more expensive products and didn't see a response that justified spending/risking more $. It has S, Mn, Mo, Zn. | |
